Hi
My blower motor was coming on intermittently - then just on med and high. One day smelled a burning electrical smell - ac blower no longer runs -
Now when I turn on blower and depress AC switch nothing happens - not even a green light by the AC button which used to always be thwere when the button was depressed.
When I depress the AC switch the engine can be heard goiong under load - the compressor runs and the rear AC blows cold (separate blower and blower switch for rear)
The front has nothing going on so I bought a switch out of the local upull a part as well as a blower resistor. I checked the blower by jumping it to the battery - front blower runs fine - swapped the blower switch and resistor but got no result - still no AC
Any clue? Are there other relays or fuses I could replace???
Thanks
Thanks
Jun 17, 2009 at 9:57 AM
