1993 Toyota Pickup Rough Idle
THEMISFIRE
my 1993 toyota pickup 200,000 miles. My truck has been running very well, up until 2 months ago i had a complete engine tune up, oil change,oil filter,fuel filter, plugs, spark wires, cap and rotor, i had taken it in because my truck was running very rough at a stop the truck would "chug" when i turn on my lights it gets marginally worse. after the tune up my truck is still idling rough and has lost lots of power and gets horrible gas millage(about 6 months ago i was getting 36 mpg!) What is the problem? i was told by my Toyota certified mechanic that it could be valves? what is the cost for valves and your opinion on the truck? i know it has a lot of miles but its Toyota i want some life out of it!!!
Sep 10, 2007 at 4:26 PM
  • 75,988 POSTS
[quote:e49ba88afd="themisfire"]my 1993 toyota pickup 200,000 miles. My truck has been running very well, up until 2 months ago i had a complete engine tune up, oil change,oil filter,fuel filter, plugs, spark wires, cap and rotor, i had taken it in because my truck was running very rough at a stop the truck would "chug" when i turn on my lights it gets marginally worse. after the tune up my truck is still idling rough and has lost lots of power and gets horrible gas millage(about 6 months ago i was getting 36 mpg!) What is the problem? i was told by my Toyota certified mechanic that it could be valves? what is the cost for valves and your opinion on the truck? i know it has a lot of miles but its Toyota i want some life out of it!!![/quote:e49ba88afd]
If it was me I'll do a compression check and leakdown to know where am at on valves and rings. And do an oil pressure check to determine them engine bearings condition-if it all checks out . Then I'll maintain the rest and look for any adjustments needed and run it till it dies.
Sep 10, 2007 at 7:24 PM
Suggested Repair
Perform a compression test and a leakdown test to evaluate the valves and rings, and check oil pressure to assess the engine bearings. If those results are acceptable, continue maintenance and any needed adjustments rather than assuming a valve job.
Conversation Summary
The owner of a 1993 Toyota Pickup with 200,000 miles reports rough idle, chugging at stops that worsens with the lights on, power loss, and poor fuel economy after a recent tune-up. A mechanic suggested the valves. The expert recommends compression and leakdown tests plus an oil-pressure check before deciding on further repairs.
