"86" Toyota Pick Up runs rough
CHRISSCHRAMM
  • 1986 TOYOTA PICKUP
New engine, runs rough between 25 & 30 MPH. (Surge or missing)
and wants to run hot but has not over heated.
New EGR Valve, Carb has been rebuilt.
Any suggestions would be greatly appreciated. Its making me Crazy!
Friday, June 8th, 2007 AT 7:35 PM
KIN CHAN
  • 453 POSTS
Where and who build this engine. Who install it. Toyota 22r 4cyl. Enginehave many version. Sounds like u have a wrong combination of head and block causing a wrong cam timing. Ask u mechanic and chk the valve train with a vac gage
good luck man
Friday, June 8th, 2007 AT 7:47 PM
CHRISSCHRAMM
Thanks.
I appreciate you taking the time to share. I will check into your suggestion.
Thanks again
Chris
Friday, June 8th, 2007 AT 10:33 PM
