Overheating
SWITZCHEESE
  • TOYOTA PICKUP
'93 toyota pickup V6 200K mi (3VZ-E engine)
My truck has started to heat up immediately (within 3-4 blocks) and continues to heat up rapidly, then seems to level off a little over halfway to the red line(normally levels off about 1/4 of the way). The heater still blows hot air. Does this sound like a thermostat problem? I don't want to take it out if it's not the problem. Any response would be appreciated. Thanks, Jeff.
Wednesday, November 28th, 2007 AT 12:55 AM
You have to. Y sooner or later its gonna completely close and then Bang blown headgasket and major repair bill. Be smart
Overheating issue that's the 1st line of defense the Stat
Wednesday, November 28th, 2007 AT 2:38 AM
DGB
Know its been awhile since your post. Hope you have the problem corrected by now. If not, exercise extreme caution. Overheating is, in my opinion, Toyota's weakness. Having owned an 87 4x4, a 95 4Runner and a 99 Tacoma, have had major overheating headaches with all but Tacoma. After much trial and error, radiator needs to be suspected after 120-130k if all simple stuff has been verified ok.
Tuesday, January 8th, 2008 AT 1:17 PM
