1994 Toyota Pickup Knock Under Load
VDUBED2
I have a 1994 Toyota Pickup 3.0L V6 4x4 with 175000 miles . I have recently replaced the head gasket after repairing a stripped out spark plug socket. During this process I decided to replace the timing belt as well. After everything was back together I started it up and noticed what sounded like a very faint knocking, similar to a diesel engine sound, coming from the area where the downpipe exits the engine bay. I have been driving it like this for about 900 miles and the sound is getting much worse, now increasing in volume whe I accelerate. The timing is dead on, 10 deg BTDC, however I am not sure if I replaced the valve lifters in their original positions. Could this be the problem? I have never acutually heard what an engine knock sounds like so I am not sure if this is it either. The knock seems cyclical, like it is happening every revolution, or maybe slower. I had the heads machined prior to instalation and I think it increased the compression. I was getting readings of 170-180 psi in all 6 cylinders. Do i now need to use a higher octane fuel?
Thanks,
Matt
Jul 16, 2007 at 12:07 PM
  • 75,988 POSTS
I need to know what kind of noise-is it a ticking,tapping,thudding,thumping, or a bunch of marbles being drop into a tin can ( Detonation/Spark Knock)
BTW did you jump the diagnostic connector TE-1 to E-1 while adjusting the ignition timing.If not you need to do this to get it right.
HTH/Good Luck
Jul 16, 2007 at 10:35 PM
VDUBED2
Thanks for the quick response. The sound is more of a thudding than marbles in a can. It occurs only when the engine is under load or accelerating. If I rev the engine in neutral it dosen't occur, or it is at least so faint I can't hear it over the engine noise. I did jump the diognostic connector and the timing is dead on. My real worry is that I am doing mechanical damage to the internals. Is this a possibliliy, and what may cause it? Any more knowledge as to what it could be would be greatly appreciated.
Thanks,
Matt
Jul 17, 2007 at 7:48 AM
  • 75,988 POSTS
It sounds more like detonation,it will damage the engine-
Possible causes: EGR,engine overheating,low octane fuel,high compression,lean A/F mixture,spark plug heat range/knock sensor.
Jul 17, 2007 at 8:18 AM
Suggested Repair
Treat the load-only thudding as detonation, which can damage the engine. Check the EGR system, overheating, low-octane fuel, higher compression from the machined heads, a lean air-fuel mixture, spark plug heat range, and the knock sensor. Ignition timing was already verified at 10 degrees BTDC with the diagnostic connector jumped.
Conversation Summary
The owner of a 1994 Toyota Pickup 3.0L reports a cyclical thudding knock under load after replacing the head gasket and timing belt and having the heads machined. Timing is set at 10 degrees BTDC with the diagnostic connector jumped, and compression reads 170-180 psi. The expert identifies the sound as detonation that can damage the engine and lists possible causes including EGR, overheating, low octane, high compression, a lean mixture, spark plug heat range, and the knock sensor.
