Clutch 1995 Toyota Pickup
1995 TOYOTA PICKUP
JBECKER63
I have a 1995 Toyota Pickup 4cyl 5 speed. 100,000 miles I am having trouble with my clutch. It is eratic and does not disengage sometimes causing the engine to stall or the truck to jump forward when I go to first. I changed the slave cyninder and the truck was fine for about two weeks then it started again. i thought there may be air in the line so I bled it and then it didnt work at at all. I thought it may be a faulty part so i changed it again. It drove fine for a day and now the same problem. The clutch is not slipping it just doesnt disengage when I push in the clutch. Could their be a problem with the master cylinder?
Oct 25, 2007 at 4:07 PM
  • CERTIFIED EXPERT
Forget about rebuild kit-replace the clutch master cylinder, make sure you bleed it properly and then adjust the free play and pedal height.
Oct 26, 2007 at 3:08 PM
