No throttle response-Try disconnecting the TPS and inspect it-you see anything? put it back in. Any improvement. Also while you're under the hood check the MAF sensor its attachecd to the air cleaner look in the flap, maybe something is stuck in there or need cleaning.
If not we'll be waiting for the OBD2 code in order to proceed on.
You sure the throttle cable is not disconnected-I heard of such thing the other day here. Lets check it.
HTH-Good Luck!
Jan 31, 2007 at 7:05 PM
