1994 Toyota Pickup 22re engine prob
ALJETS4
  • 1994 TOYOTA PICKUP
  • 4 CYL
  • 113,000 MILES
Ok I have a 94 toyota pickup with 22re and I have prob cranking it will crank up for days and days but just out of no where and then sometimes I can sit for a min or 2 and it cranks up agian and then wile I am driving up hills or droping a gear to go faster it stumbals and check engine light comes on and then I let of gas pedal to shif gear and then it is ok
Tuesday, August 10th, 2010 AT 11:46 PM
Check engine light:
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis, finding out what's going on.
Wednesday, August 11th, 2010 AT 12:15 AM
ALJETS4
Ok I have had the codes checked and it comes back as spped sensor and tps but when I unplug tps it runs poorly and revs at idle and the speed sensor is not causing this prob I have unplug it and it seems to run a little better but I have put someones working speed sensor and it did not fix the prob
Friday, August 13th, 2010 AT 2:59 AM
When was the last tune-up? Cranks and hard to start, start by checking the fuel pressure if its within specs and comeback with the readings
Friday, August 13th, 2010 AT 5:09 PM
