1992 Toyota Idle
JACKIE_AZ
I have a 1992 Toyota pickup 4x4 with a 22re 4cylinder engine with a 140,000 miles on it and i am having a idle problem. The idel usually goes high and when i push in the break pedal the idle drops and then goes back up bouncing over and over. I have replace the IAC and the Mass air flow. I took it to Toyota and they replaced the valve Assy Magnet and the diaphragn sub assy and pulled and cleaned the injectors. They then told me they didnt know why it was doing it and said there where no error codes. I wondering if there is something i can do. Any help would be great. thanks and take care. Also if i let the clutch out a little with by foot on the break the idle goes back to normal. :D
Jul 10, 2007 at 8:22 AM
MMPRINCE3000
  • 133 POSTS
A high idle is usually a vacumm leak. You need to check all vacumm lines and the hose to the brake booster.
Jul 10, 2007 at 10:45 PM
JACKIE_AZ
Hi there i have checker for vacuum leaks and have failed. i have also checked the hose going into the break booster and have found no leaks. This problem does not happen all the time but is spuratic. Sometimes it runs fine and just when i think that i fixed the problem here it is again. What is the best way to check for leeks i just spayed carb cleaner and tried to see the idle jumps. Any help would be great thanks. jack
Jul 11, 2007 at 2:19 AM
