1989 Toyota Pickup fuel system
1989 TOYOTA PICKUP
202,000 MILES • 6 CYL • 4WD • MANUAL
SURRELL8
hey,
i have a 89 Toyota pickup. after i had just installed a new blower for my a/c i went to start the truck up for a test and it would not start up... so i took apart the fuel line just behind the filter, which is new too, and had to fuel pumping into the filter.. so i dropped the tank and put a new fuel pump in and i still have no fuel coming to the filter. i have spark, the engine starts when you prime the line... i am having a problem finding the issue so if you could help me i would appreciate it
Mack
May 22, 2010 at 12:04 PM
  • CAR REPAIR CONTRIBUTOR
Hi surrell8, Welcome to 2carpros and TY for the donation
Do this block open the vane flap inside the airflow meter and attempt to start, what happened still no start? Let me know
May 22, 2010 at 12:19 PM
SURRELL8
blocked the vein flap still no fuel coming to the fuel rail is there a remote tip switch on a 1989 4x4 pick up that may have been activated if so where is it located or do you have any other suggestions?
May 22, 2010 at 2:03 PM
Do you hear the fuel pump come on when you turn key on? If so check the fuel pressure with a fuel pressure gauge if its within specs and comeback with the readings so that we can to continue-
May 22, 2010 at 6:08 PM
