cuts out under acceleration?
180,000 MILES • 4 CYL • 4WD • MANUAL
87YOTA
My truck runs pretty good from 1/2 - 3/4 throttle, but when you give it full throttle it cuts out and stumbles.
Apr 27, 2009 at 9:36 AM
  • 110,246 POSTS
Does the vehicle run normally when you are below 1/2 throttle? Also, what you are describing could be a weak fuel pump or a dirty fuel filter. If the fuel that is needed is restricted, you will notice it most of all under a heavy load.
When it cuts out, does it backfire or anything other than that is out of the ordinary?
Let me know as much as you can.
Nov 25, 2023 at 1:08 PM
