1986 Toyota Pickup 4 cyl Four Wheel Drive Automatic
just replaced motor with a 94, used orginal wiring harness, and EFI manifold. I replaced the timing chain, cam gear and crank gear. Set on top dead center, adjusted the valves, had it running but motor shook real bad, pulled distributor, set on # 1, now the motor won't start. When it was running, the motor got real hot and could not advance or retard the timing by turning the distributor. Have tried setting distributor on # 1, everything looks good but will not start.
SPONSORED LINKS
Tuesday, May 26th, 2009 AT 2:16 PM
