1986 Toyota Pickup Cuts out (like switching on/off while dr
186,000 MILES • 4 CYL • 4WD • AUTOMATIC
T-CRAW
Hey Fellas.
Got a 22RE engine (fuel injected of course)
Bout a month ago, truck started missing. Diagnosed problem. Was plug wire (abraded). Replaced wires, plugs, dist. cap, and rotor. Great.....Solved the miss and things are better than before... right? Well, not quite. Upon commute to work it started cutting out periodically like the ignition switch was turning off then on very quickly. Checked wires again, everything looked fine. Started happening more often (a dozen times in a 12 mile range). OK, sounds like a pick-up coil (actually I figured it was merely the wires becoming brittle and with moving them around during replacement of everything mentioned above, maybe IT needed replacement).... after all, it is probably original making it 23 years old and the wires were pretty stiff.
Shelled out 90 bones for a new pick-up. Alright. This is certainly going to solve it. Thought it did for the first 3 or 4 miles. Then it's back to the same old cut-out pattern. It can occur many times in one mile or stay symptom free for several miles, but it always does it several times during each 12 mile commute to work. Never dies, just gets disconnected from life for a milliesecond and makes red engine light on dash illuminate briefly (if you blinked you would miss light coming on) but you definitely feel it.
I'm thinking it may be the wires from the pickup coil connection to the ignition coil. Just a few feet long but I did move them around when I did the whole tune up thing and they may be in poor shape and flex somewhat from the wind caused by the fan when driving.
Just to recap; Never had this problem before until after I tuned up engine with new plugs, wires, dist. cap and rotor.
Any suggestions?
Regards,
t-craw
Feb 4, 2009 at 11:45 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds like you may be on the right track.....The way the wires on those 22res go across from dist to fender over the exhaust manifold, they can get brittle.Also be sure coil wire is plugged into dist real good.Sometimes you have to wait for a failure to find something like this, hopefully iti just some bad wiring. I had a 85 SR5, 5 speed, 22re straight axle 4x4. best truck I ever had, regret getting rid of it
Feb 5, 2009 at 12:03 AM
