Hows the S-10? I gave you something on it again-go do it
For this one-check the compression both wet/dry readings. BTW when you pulled the plugs out did you see any coolant? Could be hydro-locking or mechanical problem within
SPONSORED LINKS
Tuesday, June 10th, 2008 AT 11:50 PM
