1985 Toyota Pickup Engine Overheating
1985 TOYOTA PICKUP
110,000 MILES • 4 CYL • 2WD • AUTOMATIC
PICK19782003
My 1985 Toyota SR5 Pickup truck was overheating. I discovered my lower radiator hose that connected from the pipe to the water pump was torn. I replaced that hose with a new one. It still overheated. I noticed that I had a pin hole on the top of my radiator and JB welded it. It fixed it, but again it overheated. I replaced the thermostat today, and it overheated again. After it overheated this last time, I opened the hood and say my engine, itself, smoking. I keep on fixing these problems. Being a novice, I can't troubleshoot this problem though. What could possibly be wrong? Should I fix it myself or should I take it in? How much would each choice run about?
Apr 10, 2008 at 8:19 PM
  • CERTIFIED EXPERT
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump
Apr 10, 2008 at 10:20 PM
