1993 Toyota Paseo Weather Idle Stall
JRODKS
I have a 1993 Toyota Paseo, 5 speed stick with 223K miles that's still going strong. Over the last year and a half I've had an EGR valve replaced, changed plug wires, plugs, replaced fuel filter, etc.. When the weather hits extremes I have an idling/stalling problem. In cold weather it hates to start. In hot weather it starts fine but often when I press on the accelerator from a dead start (at a light, ie) than it stalls out. In moderate weather it runs fine. Any ideas?
Aug 29, 2007 at 9:49 AM
  • 75,988 POSTS
It probably needs a major retuning.
Inspect and test the coolant temperature sensor and the throttle position sensor, Oxygen sensor/s to include the MAF. Might also check what's happening with the fuel pressure with a gauge
Nov 4, 2007 at 8:35 PM
Suggested Repair
Perform a major retune. Inspect and test the coolant temperature sensor, throttle position sensor, oxygen sensors, and MAF, and check fuel pressure with a gauge.
Conversation Summary
A 1993 Toyota Paseo with 223,000 miles is hard to start in cold weather and often stalls when accelerating from a stop in hot weather, while running fine in moderate weather. Recent work included an EGR valve, plugs, plug wires, and fuel filter. The expert recommends a major retune and testing the coolant temperature sensor, throttle position sensor, oxygen sensors, MAF, and fuel pressure.
