Toyota Corrola has no firing, no fuel, no check engine light
JULIUS C ALLEN
  • TOYOTA
I have a Toyota Corola, 1994, 1.8 engine, 120,000 miles. It does not have firing, cannot get fuel and the check engine light does not come on when starting.
Tuesday, March 6th, 2007 AT 10:53 AM
Check the EFI and Ignition fuses-okay swap or replace the EFI relay and comeback I've been here before. The same symptoms
Wednesday, March 7th, 2007 AT 5:59 AM
JULIUS C ALLEN
I have checked completed this process. Still will not start.
Thursday, March 8th, 2007 AT 5:54 PM
I have checked completed this process. Still will not start.[/Quote:2cf7c234e0]
Check the circuit opening relay this one powers the fuel pump and half of the main sensors.
Friday, March 9th, 2007 AT 2:16 AM
JULIUS C ALLEN
I have checked completed this process. Still will not start.[/Quote:469ff2ae7b]
Check the circuit opening relay this one powers the fuel pump and half of the main sensors.[/Quote:469ff2ae7b]
The circuit opening relay works properly when trying to crank engine. Is there any thing else I can do?
Friday, March 9th, 2007 AT 5:44 PM
