1996 Toyota Tacoma Horn Not Working
TOYOTA
RLMARTIN71
The horn on my toyota tacoma 96(155,000 miles)
4 cylinder-engine is not working. I noticed the bell was
dangling from below the bumper. What should I be
checking and where. Thanks so much for your help.
Feb 5, 2007 at 3:00 AM
LOSONE
  • 1,616 POSTS
Disconnect the horn and check that you have voltage on one side. Put a test light across the horn connector and have someone press the horn. If it lights then it is a bad horn. If not it could be a fuse, horn relay or horn switch. They are usually bullet proof with the horn having the highest failure.
Good Luck losone
Feb 5, 2007 at 3:37 AM
Suggested Repair
Disconnect the horn and check for voltage at the connector with a test light while someone presses the horn. If the light comes on, replace the horn. If not, check the fuse, horn relay, and horn switch.
Conversation Summary
The owner of a 1996 Toyota Tacoma says the horn does not work and the horn is dangling below the bumper. The expert advises testing for voltage at the horn connector while the horn is pressed. If voltage is present, the horn is bad; if not, check the fuse, horn relay, or horn switch, noting that the horn itself is the most common failure.
