1988 Toyota High Crankcase Pressure
TOYOTA
JJDAZ
I have an 88 toyota 4x4 with a 22re motor 200,000+ miles while driving down the highway it began to quickly lose power and oil. i managed to get it home requiring 6 qts of oil and have since discovered that it is being blown out of the vent in the valve cover pcv valve is ok egr valve vacuum line was plugged but now clear. the crankcase pressure is incredibly high and i dont know why please help
Feb 8, 2007 at 10:34 PM
  • 75,988 POSTS
[quote:f8cc6d16d8="jjdaz"]I have an 88 toyota 4x4 with a 22re motor 200,000+ miles while driving down the highway it began to quickly lose power and oil. i managed to get it home requiring 6 qts of oil and have since discovered that it is being blown out of the vent in the valve cover pcv valve is ok egr valve vacuum line was plugged but now clear. the crankcase pressure is incredibly high and i dont know why please help[/quote:f8cc6d16d8]
Change the PCV valve and inspect both hoses going to and from the valve cover to the throttle body assy.
Feb 8, 2007 at 11:10 PM
Suggested Repair
Replace the PCV valve and inspect both hoses between the valve cover and the throttle body assembly.
Conversation Summary
The owner of a 1988 Toyota 4x4 with a 22RE reported sudden power loss and heavy oil use on the highway, with oil blown from the valve cover vent and very high crankcase pressure. The PCV was believed to be okay and a plugged EGR vacuum line was cleared. The expert recommends replacing the PCV valve and inspecting both hoses from the valve cover to the throttle body.
