2002 Toyota Camry Speed Bumps
TOYOTA
MICHELLERAE
My aprtment complex put in eight speed bumps (four going into the complex and four going out). These are very large, poorly made and are now chewed up from snowplows. There is no way to avoid them and on a daily basis, I go over all eight of them about 3-8 times. Is this going to cause damage to my car at some point? It's an '02 Toyota Camary with 110,000 miles.
Mar 22, 2006 at 6:57 AM
PEPPERMRJ
  • 1,158 POSTS
Go over them slowly and carefully and you will be OK. Sounds like overkill huh?
Good luck. :)
Mar 22, 2006 at 10:21 AM
Suggested Repair
Drive over the speed bumps slowly and carefully to reduce the chance of damage.
Conversation Summary
The owner of a 2002 Toyota Camry with 110,000 miles asked whether repeatedly crossing eight large, poorly made, snowplow-damaged speed bumps several times a day could damage the car. The expert advised going over them slowly and carefully and said the car should be fine.
