1998 Toyota Siena Electric Problem
1998 TOYOTA
JMKENNETT1
Hi. I was stopped at a light and my after factory radio started blinking and the sound went off. Took the face plate off and put it back on, but it still blinked with no sound. I then turned the car off and when I tried to turn it on, there was nothing but clicking noise (dead battery sound) and it wouldn't start. Other electric things worked fine (interior lights, hazards, etc) Got a jump and it started right away. All other electic functions are working normally. An hour later started the car with no problem. Radio and everything else worked fine. What could be the problem? Thank you
May 20, 2007 at 10:35 PM
  • CAR REPAIR CONTRIBUTOR
[quote:c54a540583="jmkennett1@cox.net"]Hi. I was stopped at a light and my after factory radio started blinking and the sound went off. Took the face plate off and put it back on, but it still blinked with no sound. I then turned the car off and when I tried to turn it on, there was nothing but clicking noise (dead battery sound) and it wouldn't start. Other electric things worked fine (interior lights, hazards, etc) Got a jump and it started right away. All other electic functions are working normally. An hour later started the car with no problem. Radio and everything else worked fine. What could be the problem? Thank you[/quote:c54a540583]
Could be the battery and its connections or an alternator problem
May 20, 2007 at 11:23 PM
