clutch problums some help me please!
TOYOTA MR2
KMYRICK628
i have a 91 turbo 2.0 mr2 with about 163*** miles. i dont know if it needs a new clutch or what iv never had this problums with a car before. so hears the problum, it seems like the clutch is not ingaugeing. its stuck in nutral and wont go into any gear when running. i have a remote start for it so i dont need the clutch to start it. when its off obvioulsy it goes into the gears just fine. heres a thing i dont get, i was driveing the car and this happend, i waited a little bit and it worked fine for a day. but then it did it again and again i waited and it started to work again. but now it just wont work. someone please help me i have no clue what is going on. THANKS
Oct 10, 2007 at 3:55 PM
2CARPRO JACK
  • CAR REPAIR CONTRIBUTOR
  • 11,533 POSTS
Does the pedal feel normal? Sounds like something is broken and bouncing around in the clutch assembly
Oct 10, 2007 at 4:03 PM
KMYRICK628
yea it feels normal i just have no clue what the problem is and i dont want to waste money on parts i dont need
Oct 10, 2007 at 7:18 PM
2CARPRO JACK
  • 11,533 POSTS
If the pedal feels normal and the clutch only works sometimes, it is broken internally and needs to be taken apart to see exactly what happened
Oct 11, 2007 at 6:38 AM
KMYRICK628
ok ill do that and see whats going on. but yea now it wont go into any gear what so ever its stuck in neutral.
THANKS for the help
Oct 11, 2007 at 1:07 PM
