2000 Toyota MR2 water drainage
2000 TOYOTA MR2
50,000 MILES • 6 CYL • 2WD • MANUAL
REDHEAD54
where does the water drain from on a soft top as i have water coming filling up behind the drivers seat,and there are no leaks in the roof
Jul 12, 2009 at 1:02 AM
PATMARS
If you have water filling the inside of your MR2, it is coming directly from where the top meets the side of the car - you can actually put your whole hand inside the car - there is no seal here. Why they did this, I do not know. The water flows into the boot portion, where the top sits when it is down, and then flows out drain holes in the bottom of the boot. These can easily get clogged. You can feel them in either corner. Just insert a flexible wire and use that to push out any obstructions.
Sep 10, 2010 at 6:09 AM
