1994 Toyota MR2 keeps stalling
1994 TOYOTA MR2
OCONNELL17
Engine Mechanical problem
1994 Toyota MR2 6 cyl Two Wheel Drive Manual
i recently tried to put a k & n air filter on my toyota mr2. It did not work as it started up then the engine suddnly died!
i put the orginal air filter back on and now it starts up, it will tick over then die, i use the gas and it still dies!
Jun 10, 2008 at 11:18 AM
KHLOW2008
  • 41,814 POSTS
Hi oconnell17,
I believe this model is equipped with air flow and you have a vacumn leakage between the air flow and throttle body. Some hose must have not been installed properly.
Jun 15, 2008 at 4:49 AM
