1985 Toyota Land Cruiser Melted Battery Post Fix
QUINNY
Hi, I recently had a new battery put in my 85 Landcruiser. The connection must have been loose because the negative post melted the other day at startup. About 60% of the post is left. Can I salvage it? Rebuild or mold a new one? Thanks!
Jul 2, 2007 at 10:18 AM
  • 31,937 POSTS
Hi there,
Not realy, you should cut your losses and install a new battery, & make sure that the terminals and clean and tight.
Mark (mhpautos)
Jul 20, 2007 at 7:28 PM
92 MAX
  • 36 POSTS
Hi Quinney
Itf there is enough of the post left to drill a hole through it to take a 6 mm bolt I'd certainly try it, smother the whole lot in vasiline when done to reduce corrosion, try not to rotate the post during repair as this is a sure way to break the seal between the post and battery case, then acid will wick up and corrode the post and connection.
Regards Don
New Zealand
Jan 19, 2010 at 9:37 PM
Suggested Repair
Replace the battery rather than rebuilding the melted post, and install it with clean, tight terminals.
Conversation Summary
The owner of a 1985 Toyota Land Cruiser said a loose connection melted about 40 percent of the negative battery post at startup and asked whether the post could be salvaged or rebuilt. An expert advised replacing the battery and making sure the terminals are clean and tight. Another participant suggested drilling the remaining post for a bolt and coating it with petroleum jelly if enough material remains, without twisting the post.
