2002 Toyota Highlander evap codes
119,000 MILES • 6 CYL • 2WD • AUTOMATIC
RJKSKEETS1
What could be causes of evap codes p0440,p0441,p0446 and what is book time and ballpark cost to fix?
Jul 10, 2010 at 4:15 AM
BLACKOP555
  • 10,386 POSTS
p0440
•The gas cap is not installed or working properly
•The purge solenoid has failed
•The canister is plugged
p0441 has to deal with purge solenoid also.
p0446 has to do with the vent valve.
sounds to me like the canister is plugged causing no venting or purging, if that is not the case i would check for voltage and ground at the vent solenoid and manually actuate them to see if they work
Jul 12, 2010 at 12:18 PM
