2001 Toyota Echo
SPADER
  • 2001 TOYOTA ECHO
Heater problem
2001 Toyota Echo 4 cyl Two Wheel Drive
In my 2001 Toyota Echo, whenever I turn on the fan, either air conditioner or heater, it starts to make a humming noise. The faster the fan is blowing, the louder the humming noise is.
Wednesday, December 10th, 2008 AT 5:16 PM
AL.HARTMAN
Sounds like your heater/ac intake has ingested a foreign object. Look under your center console for debris being sucked into your fan area. It could also be your fresh air/recirculate switch may be broke, it happened to mine and I pulled the front panel off and moved the switch to fresh air and have not had a problem since.
Friday, January 9th, 2009 AT 7:24 PM
