Battery
4ROSES
I have a 1989 Cressida. I replaced the battery. The lights are now turning on and off and the horn is now honking on and off. I believe some switch has to be reset. I only have one key and don't have any keyfabs.
Feb 2, 2007 at 7:23 PM
GARFIELD
  • 197 POSTS
Could you explain a little more. Are you asking is 12-13 volts normal for the battery? If so yes 12.5 and slightly higher is normal for a battery with the car not running. If you are getting that voltage when the car is running I would look at the alternator and have it tested since you should be getting around 14 volts with the car running.
Feb 2, 2007 at 10:25 PM
  • 75,988 POSTS
[quote:3babd8c7fe="4Roses"]I have a 1989 Cressida. I replaced the battery. The lights are now turning on and off and the horn is now honking on and off. I believe some switch has to be reset. I only have one key and don't have any keyfabs.[/quote:3babd8c7fe]
Could be the Auto Theft Deterrent
Feb 3, 2007 at 7:22 AM
