1992 Toyota Corona My car suddenly stops
1992 TOYOTA CORONA
KEINJEE
1992 Toyota Corona Front Wheel Drive Manual 150000 miles
Hi, Im Ray and i have a toyota corona 2.0 92 model and im having a problem when im driving for about 30-40minutes it suddenly stops when my temperature gauge arrow reaches the middle, and after cooling it down for about 30minutes i can start the car back again. i hope you can tell me how or where the problem might be thanks.
Aug 5, 2009 at 9:22 PM
Next time it stalls don't wait do below to catch it
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor /distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Aug 5, 2009 at 9:25 PM
