Interior light door switch
TOYOTA COROLLA
SKIPPER50
1993 Toyota Corolla wagon, 1.8L, 124,000 miles.
Suddenly, the interior dome light fails to work when opening the driver's door, although it works fine with the passenger door and wagon liftgate. This model also automatically turned off the headlights with the engine turned off and the drivers door open. That, too, no longer works (it is triggered by the same door switch as the dome light, I believe).
Is the problem likely the switch, fuse, relay, or what?
Thanks so much.
Oct 25, 2007 at 12:28 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
Likley to be the switch in the driver's door...all others work, check that first.
Oct 25, 2007 at 12:39 PM
