Toyota Corolla, 1990, miles 219, 859
Whenever I make left/right turns my car makes a grinding noise. I took the car in for an oil change, and the mechanic suggested this, "Half Shaft (front-left); CV5576 L REMN CV COMPL ASSY; remove & inspect axle shaft assembly, one side"
Is this what's making the grinding noise? If un-repaired, will damage occur?
Thanks!
Thanks!
Oct 15, 2006 at 6:40 AM
