1985 Toyota Corolla Coolant Leak
MARKCORINNA
  • 13 POSTS
Hi, I have a 1985 Corolla FX-GT 1600 (done 200,000kms) which has coolant leaking from behind one of the flywheels (or cog, or pully) below the cam belt cover. I can see the water leaking from behind the fly wheel when I look through the wheel arch. The water is a muddy brown color. I hope it is as simple as replacing a seal. Thank you. Mark
Apr 11, 2006 at 9:34 PM
LOSONE
  • 1,616 POSTS
AS I remember, the water pump is cam belt driven. It sounds like a bad water pump. Also you will need a new timing belt and a tensioner if that is the case. Good Luck
Apr 11, 2006 at 11:44 PM
Suggested Repair
Replace the water pump. Because it is driven by the timing belt, also replace the timing belt and tensioner.
Conversation Summary
The owner of a 1985 Toyota Corolla FX-GT reports muddy brown coolant leaking from behind a pulley below the cam-belt cover, visible through the wheel arch, and hopes a seal is the cause. The expert says the water pump is timing-belt driven and the leak sounds like a failed water pump, so the pump, timing belt, and tensioner should be replaced.
