Hi there,
I would drain the gear box and check for metal contamination, it sound like the lay shaft bearings have failed, transmission load is not through the lay shaft in to gear so you will normally not hear a faulty bearing in top.
Mark (mhpautos)
SPONSORED LINKS
Sunday, October 7th, 2007 AT 12:06 AM
