2007 Toyota Corolla Alignment Problems
DAVEPIKE03
Drive Train Axles Bearings problem
2007 Toyota Corolla 4 cyl Two Wheel Drive Automatic
The other day I slid into a curb and it knocked the alignment out of place by a difference of about 45 degrees between the steering wheel and the tires. Every time I go around a curb, the tires squeal. Is this normal when it is out of alignment? I just want to know if there could be more damage that I'm not aware of yet. i plan on taking it to a mechanic in a few days but I was just wondering if you might know
Jul 20, 2010 at 9:36 AM
FORDRACING24
  • 65 POSTS
That is quite a bit out of alignment and yes you could have done some other damage besides just needing an alignment.
Jul 20, 2010 at 1:52 PM
MMPRINCE4000
  • 8,548 POSTS
You knocked out toe or camber and bent some suspension components.
Jul 20, 2010 at 11:52 PM
