2006 Toyota Corolla
RAY2434
  • 2006 TOYOTA COROLLA
  • 4 CYL
  • 4WD
  • MANUAL
  • 47,500 MILES
The other day I was getting on the expressway and as I hit the gas to accelerate the engine hesitated and only accelerated at a very slow rate. If I gave it too much gas it began to shake. The check engine light came on and has been on ever since. The engine has the same issue while idling at traffic lights.I put the car in park at stop lights in fear that the shaking will lead to a stall out. It seemed a couple of times the engine "caught" really quick and would accelerate at a normal speed but then returned to the shaking/hesitating. I replaced the spark plugs and the ignition coil but the problem still exists. Thank you.
Friday, May 28th, 2010 AT 7:59 AM
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis, finding out what's going on.
Friday, May 28th, 2010 AT 7:11 PM
