2005 Toyota Corolla Dashboard Malfunction
ELISHAFRUMKIN
  • 2005 TOYOTA COROLLA
2005 Toyota Corolla 83000 miles
Every so often, all of the sensors on my dashboard essentially freeze - when I turn the car on, the odometer is blank, and when I drive, none of the gauges move at all, including my gas indicator, the spedometer, or anything at all. Sometimes this will last an hour, sometimes a few days, and then it goes away. Any idea what might cause this?
Friday, November 21st, 2008 AT 10:49 AM
MMPRINCE4000
  • 8,548 POSTS
More than likely an intermittent short or open circuit in the IP itself, since fuses and fuseable links do not repair themselves.
It will be necessary to remove the IP and check the circuit board.
Saturday, November 22nd, 2008 AT 5:37 AM
