2004 Toyota Corolla Repair Cost
TCHRBETH
  • 2004 TOYOTA COROLLA
Transmission problem
2004 Toyota Corolla 4 cyl Automatic 88,895 miles
My transmission is apparently about to go since my transmission fluid is black and smells burnt. The car has no indications that anything is wrong. If I repair it now, before the transmission actually slips, what is a reasonable cost estimate for a rebuilt transmission?
Thursday, November 5th, 2009 AT 8:00 AM
STEVEW84
  • 673 POSTS
I would say wait. If you want to get a used one then parts and install then probably at least 1500. HTH.
Thursday, November 5th, 2009 AT 9:48 PM
MMPRINCE4000
  • 8,548 POSTS
I would go ahead and change fluid and filter, make sure the oil cooler lines are not blocked. Look for any metal shavings in pan.
As mentioned either a rebuild or a remanufactured trans will run around $1500-2000 plus install.
Another option is to get a used trans from junkyard.
There is no scheduled maint. For this trans, so either the oil cooler is blocked or you tow items with car?
Friday, November 6th, 2009 AT 7:09 AM
