2004 Toyota Corolla Questions Answers
ZEHSAN
  • 2004 TOYOTA COROLLA
  • 4 CYL
  • 4WD
  • 17,000 MILES
Just a month ago I bought this car. How should I maintain in general to keep it well ang good?
Thursday, July 16th, 2009 AT 10:16 AM
MMPRINCE4000
  • 8,548 POSTS
First, read the owners manual.
Second, read the owners manual again :).
The manual will give you all the necessary maint. Info.
Later model Toyota's generally require little maint.
Most important, change oil/filter every 3,000 miles. Change (flush) cooling system every 2 years/24,000 miles.
Check under the car and look for any leaks e.G. Trans fluid, coolant, oil and repair if needed.
NEVER overheat this engine, if the temp. Gauge ever heads toward the red, pull off the road and let it cool and get the problem fixed ASAP.
The 1ZZFE engine used in the Corolla is a very reliable engine overall.
Thursday, July 16th, 2009 AT 10:31 AM
Related General Content
