2003 Toyota Corolla Transmission Problem
YAMNET
  • 2003 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 36,000 MILES
I have 2003 Toyota Corolla 2003 (NZE) 1NZ-FE.
When my car is wormed up number 1, 2 and probably 3. As soon as it shifts from first to second there is a pause, and the gear changes, if I was to mash down aggressively it changes good, the problem is stop and Go.
(1) Oil level good no leaks.
(2) From N to P and R the gear selects on time, overdrive good.
(3) The color of oil is light red/ brownish
Another problem recently when driving slowly
on second gear, to stop I let my foot of the gas, and I notices my RMP would drop and go back up, normally the car would slow down evenly, now it feels like a break and the release. But at high speeds slowing down the car reduces speed normal.
Please Help!
Wednesday, May 26th, 2010 AT 8:27 AM
MMPRINCE4000
  • 8,548 POSTS
There is nothing serviceable in trans for Diy'er.
Take to Toyota or trusted garage for diagnosis.
Could be shift solenoid, linkage.
Thursday, May 27th, 2010 AT 8:22 AM
YAMNET
Thanks, the first thing I did was change the oil, with the original and it work the car is shifting good so far.
But I still have the other problem!
Tuesday, June 1st, 2010 AT 4:50 AM
MMPRINCE4000
  • 8,548 POSTS
Changing fluid is one thing to do as well as chech for leaks.
But as I said, shift solenoids and other internal transmission problems should be looked at by a pro.
Tuesday, June 1st, 2010 AT 8:33 AM
ROBERT PHILIPPA
My transmission doesn't want to shift into reverse. Forward works fine. Beverly a problem nefore
Monday, November 14th, 2016 AT 11:24 AM
