2003 Toyota Corolla check engine light
LADYINDISTRESS99
  • 2003 TOYOTA COROLLA
Engine Mechanical problem
2003 Toyota Corolla Engine Size unknown Wheel Drive Type unknown Automatic 90000 miles
my check engine light came on today and the engine started to shake, it shakes even more when I put the car in drive and drive it, but not as much as when I press on the break. When I checked the oil it was dry I think I might have an oil leak b/c I just got an oil change, but when I noticed the problem I just put a whole gallon of oil in the car and it is still happening. I dont know what the problem is or what to do please help.
Friday, March 14th, 2008 AT 10:29 AM
MMPRINCE4000
  • 8,548 POSTS
You can go to an autoparts store and get the codes read for free. This will give you a starting point.
But the bigger problem is running the engine dry of oil, you should have seen an oil warning light on the dash, and a lot of valve noise.
If you have an oil leak that drops 4 quarts, you should see a significant puddle of oil under the car, and oil on the bottom of the engine.
Also do not overfill the engine with oil.
Saturday, March 15th, 2008 AT 7:35 AM
