The oil in my Corolla also mysteriously disappears. There are no oil leaks and no blue/black smke from the tailpipe. Changing it regularly is something I've always been careful with. Last time I checked it was nearly out of oil. I filled it to the correct specification and the engine developed a tapping sound (like a valve tap) immediately afterward. It can be heard any time the engine is running but especially at the high end of RPM before the car changes gears. The car has always run perfectly otherwise. Is adjusting the valves (assuming this is the problem) easy to do on a 2002 Corolla?
Oct 16, 2008 at 9:58 PM
