2002 Toyota Corolla Engine stalls
ROBSTOY
  • 2002 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 180,000 MILES
Why does my car suddenly stall while driving? My car stalls after getting very hot and chek eng light comes on, Auto zone scanned 1300 code, igniter #1 circuit fault. What doe this mean? The car will start & run smoothly after it cools down for several hours. We are having record temps 98 degrees so maybe something fried in ignition system. Can ignition coil be the culprit?
Tuesday, July 6th, 2010 AT 10:31 AM
MMPRINCE4000
  • 8,548 POSTS
The ignitor, sometimes called ignition module is the problem.
This is a part of PCM.
Wednesday, July 7th, 2010 AT 8:10 AM
ROBSTOY
  • 14 POSTS
As far as my knowlege my car doesnt have igntion module; Isnt the igniter in the ignition coil over plug?
Wednesday, July 7th, 2010 AT 4:37 PM
MMPRINCE4000
  • 8,548 POSTS
It's part of PCM.
Thursday, July 8th, 2010 AT 9:03 AM
ROBSTOY
  • 14 POSTS
Is PCM same as ECM? My manual calls it engine control module. What part do I need to replace to fix stalling problem?
Thursday, July 8th, 2010 AT 11:00 AM
MMPRINCE4000
  • 8,548 POSTS
PCM is same. You will need to scan PCM for errors.
Friday, July 9th, 2010 AT 8:30 AM
