2002 Toyota Corolla
ASHMANS
  • 2002 TOYOTA COROLLA
2002 Toyota Corolla Two Wheel Drive Automatic 190096 miles
i realize that when ever I start my car it just crawling it seem like the engine is struggling, even if am pressing out the gas it is just crawling until maybe after 3minute it pick up on start to run alright
i change the transmission filter, the gas filter the injector and the air cleaner and it is the same thing.
what else can I do?
Monday, December 1st, 2008 AT 1:09 PM
MMPRINCE4000
  • 8,548 POSTS
Check fuel pressure with a mechanical gauge. IF OK, then hook up to scan tool in live data mode and check advance computer is showing.
Remove and clean the IAC and throttle body.
Perform a backpressure test on the CAT, it may be partially clogged.
Tuesday, December 2nd, 2008 AT 8:45 AM
THIS IS MIKE
  • 686 POSTS
You can also check your coolant temperature sensor
Friday, December 5th, 2008 AT 2:26 PM
