2001 Toyota Corolla Werid Speedometer problem
121,000 MILES • 4 CYL • FWD • AUTOMATIC
EDTA1
Hello All,
I press on the gas, and my speed is 0 (but I'm moving). I let go of the gas and let it coast, my speedometer comes alive again. I've checked the vehicle speed sensor (VSS) and it's not it. It generates about 12 volts 4 times per rev of the pinion. I'm getting about 12 volts from the harness as well. So it's not like its not getting voltage. I use an OBD reader and it corresponds to what the speedometer reads (fluctuating as mentioned). What's the problem here? Is there something that links the speedometer to engine revs? Please advise.
Apr 29, 2009 at 1:38 PM
MMPRINCE4000
  • 8,548 POSTS
VSS generates electrical output called pulses per mile. PCM converts to readable MPH, if VSS is OK then problem lies in wiring to speedometer or the speedometer gauge itself.
While possible the VSS is outputting voltage, the VSS gear mat be loose giving erratic readings.
Apr 29, 2009 at 10:22 PM
EDTA1
when you say vss gear, do you mean the pinoin that's on the end of it?
Apr 29, 2009 at 11:11 PM
EDTA1
Also, if the problem is in the guage, how do you fix that? Replace the guage? Is there a quick test to test if the guage is good or not?
Apr 29, 2009 at 11:12 PM
MMPRINCE4000
  • 8,548 POSTS
Make sure pinion is seated fully. Dealer or trusted garage can test speedomter gauge.
They can also test VSS output. If you have a scan tool you can read VSS output in live data mode.
Apr 29, 2009 at 11:49 PM
