2001 Toyota Corolla Engine light on
JOSEPH BUSH
  • 2001 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 32,000 MILES
I took my car to get looked at for the check engine light on. I was told that I need to have the Charcoal Canister Valve Assembly replaced. I was told it would cost about $900.00 to do this. Does this thing go bad this quick or should I have someone else look at it first.I only have 32000 miles on this car. Thanks
Thursday, July 24th, 2008 AT 5:09 PM
MMPRINCE4000
  • 8,548 POSTS
I would get a second opinion, although is is low mileage, it is also 7 years old.
The valve could be bad, but it would not hurt to get a second opinion (or 3rd).
If the valve is the culprit, then you can always get a used one at a junk yard.
Friday, July 25th, 2008 AT 10:35 AM
