2001 Toyota Corolla delay in Pickup
LAKSHITHAW
  • 2001 TOYOTA COROLLA
  • 4 CYL
  • 126,000 MILES
After the engine start, after keeping it stopped(engine off) for sometime, the pickup is very less. The gear engages correctly. But the pickup is not good as when the engine is hot. After it gets hot ( after 5 minutes) the pickup is ok.
The transmission oil condition is good.
Saturday, July 31st, 2010 AT 9:38 PM
  • 31,937 POSTS
HI there,
This is a bit hard to tell with pout a test drive, so what I will suggest is first get a scan to check for any unresolved fault codes, and then get a transmission specialist to take it for a road test so that he can experience this issue, I do feel that this will need a hands on test to work out what the problem is.
Mark (mhpautos)
Saturday, July 31st, 2010 AT 9:50 PM
LAKSHITHAW
Thanks mark, will do.
Saturday, August 7th, 2010 AT 11:49 PM
