My check engine light is flashing, and when I push the gas pedal it pulses. It also backfires sparatically.
Tuesday, October 28th, 2008 AT 1:41 PM
DLOBI
MEMBER
Most repair shops and auto parts stores can pull the check engine code that has tripped the light on the dash with a hand held code reader. They won't likely charge you to check it out. You need to know what made the light come on before you can fix anything.
