1998 Toyota Corolla Transmission FLuid Change
1998 TOYOTA COROLLA
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
SUB_KRISHNA
Can you let me know at what intervals the Transmission fluid needs to be changed for a Toyota Corolla. The manual recommends inspection for the most part.
REgards
SK
May 21, 2008 at 8:25 AM
MMPRINCE4000
  • CERTIFIED EXPERT
  • 8,548 POSTS
Your owners manual is the best information you have. Newer Toyota's have use a new fluid with a very long change interval. Some manuals say it would only need to be changed if used for towing (for example).
If it smells burnt or has a dark color, then I would change it.
May 21, 2008 at 7:45 PM
