I have the same car and had to replace the full Catalytic converter to clear it. I ordered one called a Perfect Fit which will allows engine to breath much better and should last. Meineke also replaced both O2 sensors at the same time since they were all plugged up. Almost $900. Total. There are some cheaper ones but they won't last as long. So you'll have to decide how much longer you will run this car.
Good luck, Eric
SPONSORED LINKS
Monday, January 18th, 2010 AT 5:43 PM
