1997 Toyota Corolla Transmission Fluid Change
1997 TOYOTA COROLLA
CHOSENDRIFTER
Transmission problem
1997 Toyota Corolla 4 cyl Front Wheel Drive Automatic
Hi, I was woundering, is it bad that my transmission is a litle over filled my Transmissin Fluid?
If I want o change my transmission fluid and it has a drain plus, is it necessary to change my filter and gasket?
My new transmission gasket is like a rubber material, do I need some kind of cement or glue or anything when doing my transmission fluid change?
Dec 20, 2009 at 5:26 AM
